Meghan54
This morning, around 6AM, 30F outside, I start the truck up, an '03 Silverado w/5.3L V-8, and the driver info. center says "Battery not charging" on my dash. This warning lasted ~5 sec. then disappeared.
Fearing a failing battery or alternator, I first drove home (this was at a store about 1mi. from the house when this happened) and hooked up my battery charger. It read a 65% charge on the battery. After a few hours on 15A charge, it said it was 100% charged.
Then, not leaving the alternator's condition to chance,took it to Advance Auto and had them test the alternator....checked out good.
Then had the battery checked. Says it's good but needed a little charge....it measured an 85% charge from this 1 mile drive to AAP and back after it was at 100% charge immediately before returning to AAP and its testing on the battery.
So, alternator is "good" and battery is "good", although something's not right. I'm really thinking it's the battery.....4 years old, a cheaper brand.
Honeslty, haven't had elect. problems at all with the truck. So, where'd you dive into first? I'm really leaning towards the battery slowly failing, but the alternator's age is unknown.
Damn, I'm sorta stumped. First inclination is to buy a battery, but at over $150 for the battery, it's not a cheap proposition. Neither is the alternator, but at least it's a tad cheaper than the battery.
In a quandary right now. What direction would you go?
