Somewhere in the $150-$175 range
Please learn to read, guys. If he says this range, please give him something to work with in his range. If you feel that he absolutely must spend an extra $25 over his range just to get a 9800 pro that he may not want, then please just suggest that as a secondary consideration, and that only, and give him something solid in his current range to consider as well. That'd be more helpful.
Yes, the 9800 pro is a great card and excellent bang for the buck, but I'm not going to tell you to get it unless you suddenly come across $25 lying in the street.
You can get an Nvidia Geforce FX 5900XT for around $170. If you can overclock it, the more the merrier. Performance is near that of a 9800 pro.
Or, if you're feeling lucky, you can get this card
here
It's a Powercolor 9800SE. If you use Omega drivers with it as opposed to ATI catalyst drivers, it will enable the card to run as an 8 pipeline card, as opposed to default 4 pipeline card that the SE cards run at. This will effectively make it a 9800 pro, for $154 shipped. Problem is, is that not all the SE cards can run with 8 pipelines without artifacts. About 65% will do it. If you feel bad about taking a chance, don't. If the 8 pipe unlock fails, you're back to ATI catalyst drivers and looking at a card that performs like a 9600XT. Just something to think about.
