Now how much faster is PCI-E than AGP?
danklumpp
608
If I build a computer, I will probably go with PCI-E, but just for curiosity, is PCI-E offering bigger performance gains over AGP than when it first started?
fstime
4,382
Don't think so.
I'd get PCI-e, doesn't look like Nvidia will be releasing AGP versions of their high end cards.
I'm sure i'll tell a difference, not from PCI-e but from the raw power of my 7800GTX.
addinator
160
at the current moment, the only way it really offers performance is in SLI. i would get a pci-e card simply because it will allow you many more upgrading options down the road.
Bateluer
27,730
8
Since PCIe cards and motherboards are plentiful and cheap, and with AGP not in any future roadmaps, it makes sense to go PCIe if you are building now. :)
BillyBobJoel71
2,610
zippo, zilch. too bad i am stuck with this agp mobo for a while. still, i could care less if i don't plan on upgrading as there are no performance advantages over AGP. the 16x does nothing but attract people that don't even know what it is.
Lonyo
21,938
Unless you are on a very tight budget, and the fact that AGP versions of cards (eg: 6800GT) are quite a lot cheaper than the PCIe versions (~25% cheaper in the UK)
imported_Bleh
433
Native PCIe cards like the ATI x850 line will preform slighty (and I mean very slighty) better on a PCIe mobo than its AGP bridged card (probably due to the bridge). One site had a comparison of the two but I cant remember which site it was.
KoolDrew
10,226
7
The performance difference between thw two is very small or even non-existant. AGP is being phased out rather quickly though.
danklumpp
608
I might be building and reselling computers, so AGP is a big price consideration here. If I would sell it on eBay, I might want to go PCI-E (people who look for gaming computers on eBay actually know what they're looking for), but if I sell it elsewhere, I could probably sell AGP and nobody would know the difference.
