Novocaine side effects...
AlienCraft
10,539
First time caller.....never had any problems or wierdness before.
Wow, did that suck! Got jittery, then a little dizzy as I left the dentist's office.
Probably should not have driven home. Felt like crap, The T.V. drove me nuts, couldn't relax had to turn it off and turn on the Enya... well not quite Enya, but close. :D
Had a temporary crown put in on the back @ 3:00pm, faded @ 7:00pm but didn't feel ok until about 10:30.
When we do the permanent one, I'm getting a driver.
I don't know if it's just old age or if he dosed me 'hot', but that sucked.
10,067
990
I just got a tooth pulled. All I had was dizziness and light-headedness.
It was more of the anxiety of seeing my tooth (looked like it was an inch fucking long) come out of my jaw. God damn. Be happy you had a root canal. I should have chosen that compared to getting my tooth pulled. Atleast my tooth didn't bleed for more than a minute during the root canal. It's been 12 hours and it's still bleeding.
Colt45
19,720
Procaine ("novocain") has been sort of obsolete for a while. It's lidocaine and relatives these days.
Unless you went to a dentist in a tin hut or something like that.
moshquerade
61,504
12
56
You are correct about lidocaine taking the place of novacaine. It also goes by the brand name xylocaine these days.
Also, it sounds like the OP's injection contained epinephrine which actually helps with delivery.
The epinephrine though can cause anxiety, dizziness, nervousness, restlessness, blurred or double vision, twitching, tremors, etc.
You really should call your Dentist's office when this happens. At least make them aware that you had a reaction so they can note it in your chart and change up the local anesthetic they use on you next time. Maybe go epinephrine-free.
Q
12,042
4
I have had about 6-7 teeth pulled when I was younger for braces. 2 without novacaine (thanks Dr. Orthodontist!) and rest with novacaine. Never had problems with the novacaine besides a numb mouth and my heart was beating pretty heavily.
destrekor
28,799
359
ooo epinephrine? do want.
but then again, not in a dentists chair. F that. I need a sedative, not the body's natural crack.
Found a dentist that appears to be covered by insurance, that offers sedation dentistry.
Mosh, are you able to help clear up some confusion about sedation dentistry by any chance?
The web page for the dentist states that they sedate you to a point where you are not unconscious, but are completely unaware of what is going on.
So... are your external senses completely gone (including vision?), and you are left simply with your imagination? Or...?
Are you able to interact with the "outside" world at all? The nerves in my mouth are like seriously insane, as a combination of lidocaine and N2O still leaves the drill sending torturous pain throughout my head, though the N2O helps put me into a daydream mode that helps masks the superficial surface drilling. If I cant do the sedation dentistry, my other option I've considered is simply denying the effects of N2O when they check the gas's progress, with the goal of hopefully getting them to increase the N2O to Air Mix ratio. :)
Otherwise, I'd admit to almost anything to escape the drill. It is seriously that intense for me, though somewhere the anxiety is likely exaggerating the pain signals.
moshquerade
61,504
12
56
I like hurricaine! :D
Coincidentally, Hurricaine is a topical anesthetic we rub on before giving the local anesthetic injection. It helps numb the tissue so you don't feel the shot... hopefully.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Yeppers but why waste it with a swab when you can dip a dill pickle (whole) in a big jar of hurricaine and get blown away? Perfect remedy for a sore throat. ;)
moshquerade
61,504
12
56
You are still able to follow simple instructions while sedated if that answers your question.
Also, you will likely still have local anesthesia administered even though you are sedated just because the procedure itself can still make you feel uncomfortable even in your semi lucid state.
moshquerade
61,504
12
56
While the pickle sounds good, there is Hurricaine in a spray form you can use to numb the throat and ease pain.
oh, and KINKY!
Locut0s
22,205
43
Never noticed any side effects from the anaesthetic shots at the dentist. Now when I got my 4 wisdoms pulled that's another story. Can't remember much of that day accept a sort of pleasant foggy feeling.
Locut0s
22,205
43
Ever feel tempted to ahhemm... "compromise" a sedated patient? Assuming said patient was a hot guy. :D():)
Udgnim
3,679
122
the only effect I've had with Novacaine is my mouth being numb
didn't notice any side effects
moshquerade
61,504
12
56
Nevah! :p
But, I have told this story here before, I do know of a guy who was sedated that had an orgasm unintentionally.
mshan
7,868
Sounds like you had a little novacaine toxicity (?)
Did dentist inject a lot more than normal (e. g. first shot didn't numb you properly), or perhaps he injected too close to a blood vessel.
AlienCraft
10,539
Back in for a height adjustment today. Yep, it's Lidocaine, and it had an epinephrine additive.
Doc says next time "no epi".
AlienCraft
10,539
Neither had I , which is what prompted the commentary. Had another crown a couple of years ago, not problems.
AlienCraft
10,539
No, I went to an out-of-network provider. <rimshot> :p
mshan
7,868
Systemic toxic reactions to locally administered anesthetics are progressive as the level of the anesthetic agent in the blood rises. Initial symptoms suggest some form of central nervous system excitation such as a ringing in the ears (tinnitus), a metallic taste in the mouth, or tingling or numbness of the mouth. advanced symptoms include motor twitching in the periphery followed by grand mal seizures, coma, and eventually respiratory arrest. At extremely high levels, cardiac arrhythmia or hypotension and cardiovascular collapse occur.[4] http://en.wikipedia.org/wiki/Local_anesthetic_toxicity
The epinephrine added allows greater total dose of local anesthetic to be administered without toxicity and also prolongs the analgesic effects.
Epinephrine getting inadvertently injected intravenously should produce a transient increase in heart rate that coincidences fairly quickly with actual injection and also dissipates very quickly.
