Noticeable difference between 533MHz & 667MHz DDR2?
RockGuitarDude
695
Thinking of getting 2 gigs of ram in my laptop. Is it worth spending more for the 667MHz DDR2 or should I go for 533MHz and save money?
A5
4,902
If your processor doesn't have a 667 bus, then there's absolutely no gain. If your processor has a 667 bus, then you don't really have a choice...
DVK916
Banned
Dec 12, 2005
2,765
This really isn't true. Core Duo has a 667 bus but you can also use 533 memory.
RockGuitarDude
695
This is the case. I got a Dell E1705 (core duo 2ghz) with the stock 1gig 533MHz ram.
Just want to know if I'll see a performance difference between 533MHz with a cas latency of 4 and 667MHz with a cas latency of 5.
A5
4,902
Ah...I'm not sure what the memory bandwidth situation is like on the new Duos, but I doubt the price/performance of 2GB of 667 (to replace the current 1GB of 533) is worth it over just buying another GB of 533...
DVK916
Banned
Dec 12, 2005
2,765
So there won't be any effect of having memory that is slower than the FSB of 667 mhz.
max2
Banned
Feb 4, 2006
538
Why get 2 gigs of ram on your laptop ?
What do you do on it?
Game?
I can only see gaming and I guess graphic designing or whatever requiring this.
Now if you were talking about a desktop I would say go ahead!
Better to upgrade to a 7200 rpm hard drive in a laptop then go to 2 gigs of ram in my opinion.
Dec 10, 2005
28,160
12,827
I game heavily hence the 2GB of ram. (World of Warcraft, CS:Source)
I don't think there would be too much difference between 533 ram and 667. The dual channel of the ram will give more bandwidth than then what the processor can access. Plus, the higher CAS latency of the 667 will offset any speed gained by the higher clock speed of the ram.
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
1GB for me is not quite enough. 1.5GB is nicer :thumbsup:, then might as well go to 2GB :p
Koing
RockGuitarDude
695
That's what I am trying to get at.
The 667MHz with a cas of 5 clocks would likely be the same as the 533MHz with a cas of 4 clocks except for the fact that it is running with the looser timings and higher clock.
Wanted to check if my logic was correct.
