nothing provides libc.so.6(GLIBC_2.14)(64bit) needed by.... issue
VinylxScratches
I can't seem to update some packages on OpenSuse 11.4.
Errors I get.
nothing provides libc.so.6(GLIBC_2.14)(64bit) needed by libopencv2_3-2.3.1-1.pm.18.6.x86_64
nothing provides libc.so.6(GLIBC_2.14)(64bit) needed by libswscale0-0.7.6-0.pm.1.1.x86_64
I have checked /lib and /lib64...
user@linux-6bgf:/lib64> ls -l | grep libc.so.6
lrwxrwxrwx 1 root root 14 Oct 8 00:20 libc.so.6 -> libc-2.11.3.so
user@linux-6bgf:/lib> ls -l | grep libc.so.6
I'm using Arch Linux so YMMV. libc.so.6 is in the glibc package, it should be the same case for you.
The hell I edited my first post and it made a second? 😕
I would try reinstalling the glibc package first. If that doesn't work I'm not sure what comes after. 😛
