Not sure if this is right place but I could use some help....
mrwabam
Hello All,
I just flashed my abit NFs-7 Mobo using abit's window's auto flash utility.
Rebooted machine, and got a CMOS- Checksum error using defaults error.
Can't get into bios, or the flash utility to fix it, system just hangs there.
Any ideas?
Read the manual for the motherboard. Look for BIOS reset.
You may be able to remove the battery from the motherboard and temporarily reset a jumper to reset the BIOS to its original settings.
If you can, it should be in the manual.
