- Apr 27, 2000
- 22,967
- 13,062
- 136
I just replaced an A10-7700k with an A10-7870k.  Before I took out the old CPU, I flashed to a new UEFI, made sure it worked before doing anything else (it did), and then removed the old CPU/installed the new CPU.  I plugged in all the vid cards (2x R9 290, 1x R9 390) after getting everything set up and booted, only to get no signal to the monitor and no obvious clue of what was wrong.
I took out all the vid cards and tried booting that way, and got an error LED code of 91 on my A88x-Pro. Poking around on the 'net indicated that the error might be some kind of initialization error, and that the RAM might need to be reseated (?!?). I did that to no avail. So I pulled the CPU, reseated it and the RAM, and finally booted up okay without the video cards.
After doing a lot of test n' tune on the new CPU, I finally plugged back in the cards and . . . no boot! Urgh. I removed the one card on the bottom (the one in the last full PCI-e slot) so I could see the error LED that is otherwise blocked by the double-slot cooler of the r9 290 that was in that slot, and this time the boot process was getting stuck on either 32 or 36. Those are "CPU post-memory initialization" codes. Hmmm. I used the DirectKey to boot straight to the UEFI, made sure all my settings were the same as before my re-installation of cards, and booted with two cards (r9 390, r9 290). Success! Then I installed the third card and . . . no boot. Same problem.
I was running just fine with three cards before, but now I'm getting memory initialization errors when attempting to run three cards. Which is annoying. The CPU *is* overclocked, and the last thing I haven't tried is setting everything back to default before installing the third card . . . but the 7700k was OCed with three cards in as well, so I'm not sure what's up. The whole thing is a bit annoying.
Anyway I'm posting it here since it's a memory initialization error, and it seems somehow linked to memory but I can't quite put my finger on how. Any thoughts/suggestions?
If this thread belongs in CPU or vid card forums, mods, please move at your discretion. Or anywhere else you think it belongs.
 Facebook
Facebook Twitter
Twitter
