I'm running Windows XP Pro. I have a single hard drive in the machine and I completely know how to run a chkdsk on it and go into the event viewer and see the results of scandisk whenever I run it.
Here is the tricky question. I have another drive that I want to start to use in a different computer. I want to test it first before I install an OS on it. I have slaved the drive in my main PC and can view it properly. I ran scandisk on it. I was not there at the end of scandisk so I did not see the results. Because my new slave drive is empty, I was not forced to schedule the scandisk at next boot up. It ran it while I was still in Windows but I walked away because it was taking so long. I got back and it said it was done. It showed no other results. Here is the question:
Where can I see the results of a scandisk I ran on a drive while not having to reboot windows?
Test this yourself if you have 2 drives in your PC. Open My Computer. Right click on your second drive. Select Properties, Tools, Check Now, put checks in the 2 boxes they offer and click start. When it is done, tell me how your determined your results. They are not in the event viewer.
