I just upgraded from a Motorola SB5121 to an SB6141. I'm with Comcast so what should have been a simple setup and swap has turned into a several day nightmare -- but the question is a simple one. I lost router and switch connectivity and all net access for a couple of days. Am now back to the simplest hookup possible. Incoming cable goes directly to the SB6141 and a length of Cat 6 cable connects the modem to the ethernet connector on a EVGA Z77 FTW motherboard. I have good download bandwidth -- measures 60 mbps consistently -- but the LED on the SB6141 is amber when it should be blue for a Gigabit connection -- which is what the port on the MB is.
This is the least of my problems, but thought I would ask. Only a modem that indicates when it is connected to a gigabit connection and a Cat 6 cable connecting to a MB which only has gigabit connectors out. But the modem is reporting 100 Mbps
Any ideas?
Any ideas?
