Originally posted by: BonzaiDuck
I agree with the above posts that 36C is a decent idle temperature. Especially, in a mid-tower case -- that's about what I would expect for a 3.4 Northwood, and I only imagine its better than decent for a Prescott 478-pin.
My view is that the cooler, the better, since the longevity of the component varies inversely with temperature, temperature change or variability, and voltage. The maximum temperatures for these processors is something around 69C or 156F.
If I have a system that shows load temperatures above 45C or 113F, I set about to rebuild it so that it shows 40C or lower at load.
And I don't use midtower cases anymore.
I'm still running tests on an XP120 ThermalRight cooler. I still have an XP90 in its box, with plans for use in a machine where the XP120 won't fit. So far, it appears that it has two things that trump ThermalTake's PIPE101 -- slightly lower load temperatures, and weight. Whoops-- one other thing --depending on the location of your Northbridge -- the XP120/90 models do not obstruct airflow along parts of the motherboard. My chipset runs about 5F cooler than with the ThermalTake PIPE101.
If you want to go this route -- with a premium-grade heat-pipe cooler -- try and get one that will fit a 120mm fan (the XP120) or a model with 92mm mounts where you can secure a 120-to-92mm fan adapter and a 120mm fan (ThermalTake PIPE101 -- no cigar for the XP90). Lower fan rpms, less noise, higher throughput in CFM (cubic feet[of air] per minute).
If you want, I could give you an entire database of fans both 92mm and 120mm which I spent a good part of the summer testing. You can get low-noise fans, but many of them have maximum speeds too low for high throughput. For a 92mm or 90mm fan, the Zalman is quiet and also spins up to nearly 3,000 rpms, so that is a good choice. The 92mm ThermalTake UFO fan spins up to about 3,600 and pushes about 82 CFM (or maybe it was 74, check it out . . ) The Vantec Tornado 92mm is noisy -- there is a motor whine that is more like a groan -- but at 5,000 rpm it pushes 119 CFM. The ThermalTake Blue LED 92mm fan is not too noisy and spins up to about 3,600 with comparable throughput to the UFO -- and not as noisy as the UFO.
The best 120mm fans that I've tried are the Silverstone 120mm rated at speed of 3,100 and throughput of 104+ CFM -- with mobo 3-pin plug and speed monitoring; the SUNON KD1212PMB1-6A (120x120x38 and a hefty 326 grams in weight) with 3,100rpm and 108CFM but no monitoring and only Molex plug; and the ThermalTake 120mm Blue LED fan -- 46 dB maximum noise but 2,600 rpm and 94+ CFM. The SUNON seems more quiet than the Silverstone -- apparently the white-noise air-turbulence causes most of the 42 dB. The Silverstone is quieter than the ThermalTake.
I can tell you about Enermax and other Sunon models. But what do you think this is? A free fan-consulting service? No ticky, no washy.
