The little light on the mobo turns on, but when I hit the power button on the case I don't get any response....no lights, no fans, no sounds/beeping, nothing.
I checked the power connectors running from the buttons to make sure I plugged them in correctly. Tried plugging them in straight into the mobo and with the Q-connector. I also did a visual check of the buttons from inside the case to see if any wires were loose or the buttons weren't depressing properly, but I can't see any problems there either.
I have an ASUS PQ-5 board and the case is an NZXT Tempest Mid-ATX
Open to any suggestions, thanks!
