Not enough Power Supply Molex Connectors
Eweissbard
Well, I really want to add another harddrive to my current PC, but it seems that I have run out of Molex connectors coming from the Power Supply. I can detach the one I am using currently for my AnandTech Case Fan(Great Fan) but I would rather keep it running to keep thing cooler. Is there anyway I add additional connectors without replacing my Power Supply?
Thanks,
Edward W.
El Paso, TX
Yes, use the Y power splitters. They can be had for $1 at shows, and probably about $5 at compusa.
Doesn't the fan have a pass thru cable?
Here's a place that sells them for $0.50. Buy yourself a couple extra connectors so you can add more fans/drives/whatever when you need it in the future. I have like 8 billion of these in my case. 🙂
