- Apr 23, 2008
- 4
- 0
- 0
Alright, well at first I thought this may have been my ISP, so I switched from AOL to Be* and this did not fix the problem.
I then figured it may have been my line so I went to a friends, yet the problem stayed the same.
The problem -
Well, when playing Counter-Strike : Source and other games, information is taken in perfectly fine, however the information sent back out is EXTREMELY low (As the print screen will prove in a second) around half of the information is lost actually. However, no chokes are shown.
Below is the net_graph of what the stats actually look like -
http://i21.photobucket.com/alb...0/TestamentU/Rates.jpg
As you can see, the output information, being the second line, is far too low. My friend's in/out are exactly equal on the far right values. Yet mine randoms from 20-50/s.
After noticing this, I have tried multiple things, updating drivers, reformatting, reinstalling CSS.
Nothing has worked at all.
Now i'll give you the names of my ethernet adapter and network card -
Ethernet adapter - Realtek RTL8139/810x Family Fast Ethernet NIC
Network card - Atheros AR5005G Wireless Network Adapter
Extra - 1394 Net Adapter.
I have no idea how to fix this problem, and the fact that with this exact same laptop I was playing games perfectly fine, then one day (I can't remember what changed, maybe an update or a change somewhere in Control Panel) games seemed to drop information, so I enabled net_graph to check the information and it was true.
I'm not sure what else i'd need to tell you all but any help is greatly appreciated.
Thanks in advance,
Testament.:shocked:
The problem -
Thanks in advance,
Testament.:shocked:
