Not enough 4 pin conections?
Adog
I've ran out of availible 4 pin connection on my MSI K8N Platinum mobo. I want to install some more lights/fans and a temp/fan control unit. My OCZ modsteam PSU doesn't have any 4 pin plugs used for lights and fans either. Is there a sleeved cable I could buy to plug into my modstram psu? The AG2 AerogateII fan/temp unit I have enough has 4pin conections on it but I'm still short on conections to my psu or mobo.
Any advice?
Thanks...
Are you talking about the standard 4 pin power connectors, coming from the power supply (IE: for power for IDE HD'z, CD-ROMz, etc)? Probably not, but had to ask.
No I'm ralking about the little tiny 4 pin connectors like used for fans. I' also need another plug to my PSU for one of the 4 pin plugs used for the floppy drive.
I already have a fan/temp unit. I just don't have any thing or anywhere to plug it in.
Ahh shoot man I'm confused... OK, my PSU came with one 4 pin molex cable that had a split with a small conector that I used to plug into the back of my floppy. I'm not sure if its 4 pin or 6 pin. I think I need one more of these. Maybe a cable with two 4 pin conections on it instead of one. I need to plug in my fan/temp unit into my psu some how? The 3 pin conectors on the back of my fan/temp unit will allow me to plug in my fans... but nothing to plug the unit into. Sorry if i'm confusing eveyone.
