- Apr 25, 2001
- 383
- 0
- 0
I currently have Windows XP installed but would like to do a format and fresh install. However, when I get to the part where it says "Press any key to boot from CDROM . . . . ." (right above that it says "Boot Record . . OK"), I press a key but then XP boots normally. I tried older versions of Windows to make sure it wasn't the CD. I disabled other boot devices in BIOS, leaving only CDROM. It seems that it goes to 5 periods each time, even though I press a key at about the second dot, and my keyboard works before (pressing DEL for BIOS) and after (in Windows).
Thanks for any advice!
