norton ghost 2k1 keeps on making corrupted images...please help
Maximus96
5,388
i run ghost 2001 to make an image of my win2k partition in ntfs, problem is after the image dump, i go and try to check the image and ghost tells me its corrupted, i scanned my HDD to make sure the drive itself is not corrupted, repeat and same thing again, please help
Radboy
1,812
Have made many images. Never had an image check indicate a prob.
This will bump u back up. ^
I'd be interested to hear what u find (Symantec sppt?).
Perhaps there's a prob running the app from W2K (I always image from DOS), or with NTFS (even tho Ghost 2001 sppts NTFS). I've never used NTFS.
MCS
2,519
Try booting from a boot disk and running Ghost from there, if you haven't done so already...
overmars
105
If ghost keeps giving you bogus images, try using a different program. Image Cast 3 provides really quick transfer speeds and is pretty easy to use. Free demo too, with most of the functionality retained. I used it on my machine that runs win98SE with no problems.
Free demo
hope it helps,
marc
