Norton Ghost 2001 Restore Problem
Serville
62
I use Ghost to back up my Win98SE system directly to CDR, and it needs 2 disc. The problem is when I restore it from the 2nd CDR, Ghost refuses to continue. It says it can not find the filename on the 2nd disc. When I check the drive list, Ghost does not even list my CDROM drive anymore, as if it suddenly dissappears. When I manually specify the drive & filename, Ghost says "Single license can not do multiple load". The same thing when I insert the disc into my Plextor, and specify the filename.
What happens ? Is there any known restriction from Ghost to restore from multiple CD ?
The strange thing is I backed up twice this system using CDRW disc , and CDR disc. And I can restore from the 2 CDRW disc with no problem. With CDR backup, Ghost always have problem with the 2nd disc --> "can not do multiple load".
Fyi, when I made the backup, everything was done successfully. I check the file integrity and Ghost says everything is okay, but this "multiple load" problem still appears in the real restore process.
Any idea ?
