Norton AntiVirus 2001 Problem!!!!!!
Skylynx
Occasionaly when Windows starts it seems to hault when it starts to load the icons on the taskbar or the bar on the bottom of screen (not the desktop).
It appears to be Norton AntiVirus because when i go into safe mode and disable NAV protect on startup it works fine.
Is their a remedy or should i not use Norton at all.
Thanks
Skylynx, what OS are you running? I recall reading recently that there's a problem w/ NAV2001 w/ Win9x. Norton is indicating that 2001 was written for Win2000.
