Lol about the 'L' 😉
Yea with your chipset voltages at default your temps should be fine I would think, although with a 379MHz FSB it will be a bit warmer than running at a default of 333MHz (or your CPUs default of 266MHz).
Temperatures & specs info for my rig
Q6600 @3.35GHz, vcore 1.328v running OCCT, 1.344v running DPAD & SETI (100% CPU load), vcore setting (IIRC) 1.40625v. HSF Thermalright Ultima90.
DDR2 800 RAM @ 372MHz (on my 'to do' list) @1.9v setting,4-4-4.
372 MHz FSB, all voltages except vcore & vRAM on auto (also on my 'to do' list 😉)
2 case fans, both 120mm, inlet & exhaust.
Ambient - 21C
System - 28C
CPU 1-4 - 49,51,46,50C
NB temp* - ~58C
Temps taken whilst running DPAD & SETI (~100% CPU load).
*NB temp taken using a Sealey Laser/infra red thermometer, +/- 2C accuracy.
Hmm, a bit warm for my liking ,the sooner I drop the chipset voltages the better!
[edit] I'm not so ure that NB temp is accurate now 🙁, I took another reading prior to setting the voltages to manual, this time it read 71C!, however I touched the HS & it was just very warm to slightly hot, I could keep my finger on it for a little while before it became uncomfortable. Also I latter noticed the instructions said it shouldn't be used to measure shiny or polished metals, so take that NB temp with a pinch of salt! 😉
Btw when I switched all the voltages to manual mains power useage didn't even drop 1w!, so maybe all the voltages were at default anyway?
