- Nov 29, 2005
- 659
- 0
- 76
anyone know some good ones? and if they would fit into a shuttle... the ones in my case are running pretty hot and i want to optimize performance
IDE controller, probably.Originally posted by: AzNPinkTuv
it says on my motherboard manual its a intel 82801er chipset.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=370485 this thing negood?
Originally posted by: Zim
No! These do dot provide anywhere near as good cooling as a heatsink with fan. I learned that the hard way.
He didn't say that he didn't have an NForce4... and you neither asked him nor qualified your response.Originally posted by: Operandi
It's enough for just about every chipset aside from the nForce4. Small 40-50mm fans are loud and prone to failure, passive should be used whenever possible.Originally posted by: Zim
The nForce4 is the only chipset hot enough that would ever need active cooling; everything else can be cooled passively. I would go with one of those Zalmans.Originally posted by: AzNPinkTuv
no nforce 4...
its like intel 865 or some crap
