Northbridge Fans Rceommendations for my MSI 7125
Jan 16, 2006
32
My MSI Neo4 Platinum (7125) is a fantastic board except for one irritating issue, the northbridge fan make way too much noise. It's now the loudest fan in my system(See my sig) Problem is it sits right below the video card so whatever I get to replace it has to be low profile. I'm looking for a reliable and quiet replacement for this 7000rpm squeeler. It should have the same or better cooling performance as the original while being and staying quiet.
I looked at the Zalman passive models but they won't fit due to the proximity of the video card. :( Any suggestions would be very appreciated.
Painman
3,728
29
86
Before buying a new chipset cooler, try doing a little work on the one you've got... first thing you can do is pull the big, nasty MSI sticker off of the hub. It might induce a little imbalance if it's not applied perfectly on center, and they usually never are... just be careful peeling it off, don't get too rough with the fan or you might damge it internally.
And oil it. Remove the fan from the heatsink, pull back the sticker on its undersie to expose the bearing, and aply a bit of 3 in 1, or even a couple drops of motor oil works well.
My Neo4 fan behaved much better after I did those 2 things...
