going5hole
I was looking for some opinions on my northbridge cooling options.
Option one - Get an Abit IS7 that has an active northbridge heatsink/fan on it.
Option two - Get an Asus P4P800 Deluxe, that has a passive heatsink on it, and then install a third party (Vantec Iceberg) heatsink and fan on it. The only problems I can see here, is that the NB heatsink on the P4P800 is held on by 4 clips, not the bolt/screw setup that the Vantec Iceberg has offered. I don't think the Asus board has holes for this to be installed, but I could be overlooking something. Can the Iceberg (or another product) be installed with these wire clips too?
Option 3 - The case I am buying (an Antec PP 1080AMG) has a fan mount on the side panel that is supposed to be used for VGA/NB cooling. I was thinking of installing a 42 CFM, 3200 RPM fan into this, with a filter to prevent dust. I just don't know if that is enough to keep the Asus' NB cool.
I've read a few sites where OCing on the Asus board is halted due to the NB being too hot, and I'd rather not jury-rig something up like the guys at Hard OCP did.
Thanks for any help/suggestions.
