Whoa!! :Q I'm surprised the sides of the case haven't caved in. 😉 j/kFan 01: 225000 RPM
Originally posted by: HiTek21
68c looks like the CPU temp and the 38c looks like the system temps, I could be wrong though. Normal CPU Temps for XP1700+ should be low 40's but since your is overclocked 68c looks about right. What heatsink are you currently running? If you're running the stock retail heatsink you might think about upgrading to a Thermalright SLK800 or if you're on a budget SK7. Tell us what your current setup is like, how many intake and exhaust fans you're running, maybe we can get a better idea and help you out more.
Originally posted by: NYHoustonman
I really personally think those temps need help, and I don't usually say that. Follow HiTek's advice...New HSF, maybe some case fans.
Seriously, a new HSF designed for overclocking and more case fans for better ventilation would probably help you to your temps down. 🙂
FYI:Temp 1 in almost every case on every pc is the "CPU" not temp2 or :,
