Normal temps for a p4 3.0 northwood?
JonnyBlaze
3,114
I haven't really monitored my temps before but I took off my Zalman to clean it and now I'm at 49c after Vista is finished booting and around 55c when its still loading things during boot up. Is this too high? Maybe I didn't put enough AS5? Are there any other programs that will check the temp I can run under Vista? I'm not too sure Vista likes Abit EQ. My mobo is a IC7-G.
I need to encode a few things and want to make sure this is ok or fix it before I try.
Thanks for any info.
JB
Edit: My system temp is 31c so it shouldn't be an ambient temp problem.
happy medium
14,387
480
I have a 3.06 northwwod my temps are at 68/69c under load conditions. My voltage is at 1.6 with a mild overclock.
JonnyBlaze
3,114
OK. I feel better now. I thought I was really really high. With a small overclock (225fsb, 3375mhz) I was idling around 52. Thats not too bad? My system otherwise keeps good temps. Whats the danger zone on the voltage?
JonnyBlaze
3,114
With 1.6v it was over 64c just at startup so i went down to 225fsb, 1:1 ram & 1.55v its idling at 47c to 48c. I never could get a good overclock with the board & chip.
BonzaiDuck
16,359
1,895
The 3.06 Ghz Northwood was a 533-Mhz-FSB model. A 3.0C Northwood runs at FSB 800.
The 3.06 is just about the worst over-clocking CPU there is -- by my brief experience, and observations from others I've seen on forum posts.
the 3.0C is a great over-clocker. With a decent "motherboard ducting" setup, I was able to keep load temperatures at 43 to 45C with a 20% OC to 3.6 Ghz. Some increase in VCore was called for -- pushing close or just beyond 1.5V.
Without the ducting, the same processor, same motherboard, same memory, same over-clock showed load temperatures around 45C or 46C -- for the most part.
But for both setups, the choice of cooling was limited to ThermalRight heatpipe coolers with 0.13 C/W thermal resistance or lower. I have enough information now to proclaim that ThermalRight out-performs the CNPS 9500 AND the 9700 with the Ultra 120 and Ultra 120 Extreme (has it been released yet?) But I doubt that the Ultra 120 installs on a socket 478 processor. Look at the SI-120 cooler. The SI-128 doesn't offer much better except for directing a bit more air to the motherboard. The XP-120 has a higher thermal resistance than the SI-120.
If your Zalman cooler is the CNPS 7000 or 7700 model, I can see why your temperatures are higher. Thermal resistance for those models is between about 0.16 and 0.19 C/W. The SI-120's C/W measured rating is somewhere between 0.12 and 0.135 C/W. The XP-120's thermal resistance is between about 0.145 and 0.16 C/W.
The 3.0C processor has a thermal power of around 82 watts. Over-clocked, it should -- or could -- exceed 105 to 110W. So choice of the most efficient heatpipe cooler could mean a reduction in load temperature of 5 to 10C degrees.
