Normal psu temps???
0roo0roo
64,795
84
i've seen lotsa postings about case/cpu temps, but none about psu temps. whats normal? i wanna know because i use low rpm fans in mine.
sandra 2002
board temp 23c
cpu temp 32c
power/aux temp 57c
i'm suspicious that sandra has numbers swapped around.
its a 2000+ palomino with a 12cfm fan, so i don't think its really 32c.
Rotax
529
interesting, didn't know power supplies had thermistors on them..
Mavrick007
3,198
Some psus might have a thermister cause you can connect the Antec Truepower to your mobo fan sensor and it might have a sensor for heat as well.
0roo0roo
64,795
84
its an antec sl350. i figured sisoft sandra was geting temps through the m/b. that bundle of cables connecting a psu to a m/b is rather wire heavy, figure it oculd have a temp sensor???? arg.
