Noooooo ... let's talk whey protein
Sep 29, 2004
18,656
67
Man, alot of love for ON here. Based on price I think I will try it out when I run out of my current stash of Body Fortress Super Advanced Whey Protein Powder. I buy it because it is $16 for 2 pounds. I can make the leap to $26 for 2 pounds of ON. Some of the stuff people buy is just way out of my budget. I can't be buying 2 pounds of whey for $50.
mple
278
Plenty of better tasting brands than ON, but not necessarily cheaper.
I like stuff by Trutein. Trutein Cinnabun and pumpkin pie both taste amazing mixed into oatmeal, GY or cottage cheese. Dymatize makes a great cinnabun casein that I use in baking. I hear Cellucor makes an excellent tasting cinnamon bun flavor as well, but I've yet to try it.
mple
278
Utilize SlickDeals. Set up a deal alert using keywords such as "casein" or "whey". You'll be stocked up with cheap protein in no time.
http://slickdeals.net/f/5903630-Dymatize-Elite-XT-Protein-8-8-lbs-total-for-54-AC-two-4-4-lb-tubs
Apr 17, 2003
37,622
I use Body Fortress between ON purchases when there are no deals...its fine.
ScottAD
735
77
I've used Isopure for a long time. Many different flavors and I generally stick to the low carb line.
If I am slumming it then body fortress.
My needs may be a bit different though. I had a gastric bypass July 31st 2012
Druidx
2,971
About 90% of the time I use ON because it mixes so easy in water, the other 10% of the time I like syntha-6 for the taste.
purbeast0
53,038
5,920
been buying designer whey for the past 5 or so years. love the flavor and it has less carbs than most. although they did change their taste a bit in the past year or so. it's still really good but i preferred the old recipe. just ordered 8lbs this morning.
Zivic
3,505
38
i used designer for many yrs. It used to be economical, <30 bucks shipped for 5 #. Now it's like 40+ bucks shipped for 4 #
purbeast0
53,038
5,920
yea it's gone up a few bucks. think i pay like $37 for 4lbs ones. i usually buy 2-3 at once though and shipping is like $6 and i get it the next day, so it's fine with me. i'll gladly pay for quality though.
Zivic
3,505
38
it's a decent quality protein, but it is based on a concentrate, which is a not an overly high %-age protein. When I bought it I mainly bought it because it was the protein I felt tasted the best.
just in comparison to some of the protein I use
18 grams per 26 gram serving which is not even 70% protein. so you are getting 1# of filler/other in each tub
compare that to the VP2 I use.
23 grams per 28 gram serving which is over 82% protein
or to ON 100% whey
24 grams per 31 gram serving which is over 77% protein
purbeast0
53,038
5,920
or to ON 100% whey
by quality i was referring to quality of taste. as i'm drinking 3 shakes a day on average, i'll gladly take the ones that taste better over the ones that taste like crap.
i definitely would be open to trying new brands though.
Cerpin Taxt
11,940
542
I get this stuff at Costco. I like it.
Ashenor
1,227
I am just a Crossfit noob (Thats for Zivic) :), but i normally just use protein once a day within 15 mins of working out. I currently am doing crossfit 5 days a week, should i be using more?
I need to get my diet dailed in a bit to, do most people eat prior to working out or after?
Zivic
3,505
38
all protein is getting expensive. designer does taste good.
mple
278
You don't need to be having whey at any particular time and you would be fine with 1.8g/kg/day. I'd recommend getting your protein from minimally processed food sources over highly processed powders, but that's my opinion. Meal timing is a matter of preference and has little effect on body composition, but use common sense. A large meal immediately before a workout is probably not the brightest idea.
Wyndru
7,318
4
I buy this stuff:
But I think it's disgusting.
On the other hand, the GNC Wheybolic, which apparently is manufactured by ON is delicious. I don't know why one tastes so good and the other is nasty.
Sid59
11,879
That was my first bag of protein, cheap enough but i didn't like not-to-my-liking taste and bad solubility. Always ended up with clumps of protein no matter how hard or long i shook it.
