Nooo, my key for the letter between t and v is st*ck!!
I thought the same thing to myself. He was talking about keys, the most logical thing would be to look down on your keyboard to see which letter was between t and v. 😛
Have the letter "u" copied to the clipboard. Any time you need to use the letter u, just ctrl + v .. or if you're not cheap like me, could buy a new keyboard. Good luck! 😀
Originally posted by: anxi80
Originally posted by: amcdonald
There's an ascii code for 'U and 'u', just look it up and remember it
U= alt+85
u = alt+885
But what happens if your Alt key or numpad goes on the fritz? You'll be reduced to using semaphores or smoke signals to communicate. 😀
Change to a dvorak keyboard and lose a different key. Or design your own mapping and put the U at the Zed location. 😉
U= alt+85
u = alt+885
My keyboard has a backup plan. Another Alt key. 🙂
that's exactly what I did - I was like "F or G, not sure"
I wore out the W on my old keyboard from too much UT (not trying to taunt you with my use of U)
