Hi Folks - I am building my next computer to upgrade from my Dell 8100/WinMe and will be starting fresh with a new HD and loading my software onto it (then using my existing HD for Data.)
1. Should I go for Home or Pro? I'll be using the comp (AMD Venice) for mostly office work, web dev, photoshop & video work (and a little Ultima Online on the side.) I can't find a chart anywhere that lists the differences between the two. I'll be the only one using this comp.
2. Are there any problems with using my existing WinMe HD as a data backup drive? Ideally I'd like to get the new comp up and running with my existing software, then put the Me HD in and transfer my data over. I guess I will then wipe the Me HD.
Thanks folks.
Thanks folks.
