- Nov 23, 2011
- 297
- 1
- 81
I've been thinking about moving up to custom liquid cooling, but there is a few things that come to mind, like some questions I have.
1. Is it worth it with the change of temps?
2. How much maintenance does a liquid cooling setup(of my choice) need?
3. What is the best, most efficient way to fill a water cooling loop?
4. Good way to avoid possible leaks? such as recommended barbs/fittings/tube?
Those are just some questions off the top of my head, but I certainly have more. My current setup is in my sig, but anyway I am using a CM V8. My main question is, depending on the price; Is it worth it to move from that CM V8 to this liquid cooling build.
Pump/Res combo: http://www.frozencpu.com/products/1...riant_Pump_Installed.html?tl=g30c97s152#blank
Radiator: http://www.frozencpu.com/products/1...ingle_120mm_Radiator.html?tl=g30c95s159#blank
CPU Block: http://www.frozencpu.com/products/1..._1155_1156_1366_2011.html?tl=g30c85s139#blank
Barbs/Fittings 6x: http://www.frozencpu.com/products/1...-_14_ID_BP-WTP-C12.html?tl=g30c407s1028#blank
Tube(not sure on the amount of length I should get yet): http://www.frozencpu.com/products/2..._Laboratory_Tubing.html?tl=g30c99s170#options
Coolant: http://www.frozencpu.com/products/2...00_ml_-_Pure_Blue_.html?tl=g30c337s2042#blank
Clamps 6x:http://www.frozencpu.com/products/1..._38_OD_Hose_Clamp_CLM-06N.html?tl=g30c289s720
I am looking for all (friendly) opinions on these choices, and will be happy to take some feedback if I should change something or not. A 120mm radiator is pretty much my only choice because of the case im using, but my CPU is the only thing ill be liquid cooling, dont have a big interest in adding the GPU to the water cooling setup.
Some extra info: Idle temps with the V8 are 39-41C Peak temps are around 60-64C
OR
Forget everything, ditch the idea, and go buy a closed loop cooler like a Corsair H80i
OR even just keep the V8 and move on.
OR
