I am building myself a gaming rig, after about 25 years away from computer games - i.e. the age of the Commodore Amiga and Atari ST!
Am trying to decide on which GPUs to purchase. I plan to end up with an SLI or CF setup, but will probably only get one GPU to start with if it is powerful enough, then add a 2nd GPU later. I have a 1440p monitor, and mostly plan on playing FPS and Rome II Total War.
Having done some research, I think I'll get either an AMD R9 290 or NV GTX 780 6GB. Would prefer the former since better price/performance ratio, but am concerned about noise and heat. Am building this in a Silverstone FT02 case. I do not want to bother with watercooling.
I have three sets of questions, that I need help with:
1) I see that the MSI AMD R9 290 Gaming 4G cards have three different modes - Silent/Gaming/OC. How do these work? How does one select the mode? Do all AMD cards have this? Is it part of the generic AMD software/driver setup or are these modes specific to particular brands?
2) Do NVidia cards have similar user-controllable profiles for different noise/heat/performance tradeoffs?
I already bought a motherboard and PSU:
MSI Z97 Gaming 5
850W Seasonic Evo Bronze Powersupply-SS-850AM2
I will be buying the Intel 4690k when it is released over here in the UK.
3) Are there any other considerations regarding heat/noise I should think about, especially with my plan to eventually have 2 GPUS in SLI or CF? For example, my MSI Z97 Gaming 5 demands the GPUs go in slots 2 and 5, which means only a single slot gap, i.e. about 20mm. Is this enough for R9 290s in CF or will the card in slot 2 tend to overheat? If I get 2 x Sapphire R9 290 Vapor-X the gap will only be 13mm. Will that be enough?
Thanks a lot everyone, in advance, for any suggestions and help!
MSI Z97 Gaming 5
