Noob putting together a water cooling system
GoodToGo
3,516
Hi everyone, putting together a water cooling system and wanted to know if the following system will be ok. I am very new to water cooling so please spot the obvious as well hehe.
1) D-TEK FuZion Universal CPU Waterblock - 1/2"
2) Laing D5 Vario/Swiftech MCP655 Inline 12V DC Pump
3) Thermochill PA120.3 Radiator (Barb Type : Translucent Polypropylene)
4) 7/16" ID (5/8" OD) Masterkleer General Purpose Clear PVC Tubing
5) 1/2" OD T-Fitting (for 1/2" and 7/16" ID Tubing)
6) Danger Den Delrin FillPort
7) Thermochill PA120.3 Fan Shroud
8) UV Reactive Pentosin G11 Coolant Additive (Blue) - 4oz.
9) 120mm Yate Loon D12SM-12 Case Fan - Black (70.5 CFM, 33 dBA) - Qty 3
aigomorla
21,087
3,595
everything looks good.
However that thermochill plastic barb is prone to leaking.
You should use some plumbers tape of find a metal replacement barb for it.
Also, are you cooling a quadcore? or a dual core?
Quadcores have been shown to be better on an apogeeGTX over a d-tek fusion, you get more stable temps across all 4 cores. Larger cooling area on the GTX vs Fusion.
For that kind of system, i would also recomend a gpu block. That PA should handle it without a skip in its heartbeat.
GoodToGo
3,516
I dont think I can find a metal replacement barb for it. think I will just stick with plumber's tape :(
I will be cooling a Q6600 on this setup, let me see if the GTX is available from the same store.
I am little scared to add a GPU water block becuase AFAIK, removing the heat sink from the vid card voids the warranty. If I am wrong, please correct me but that was my thinking.
Also I am thinking about getting the mountain mod case, do you see any other components I would need to accomodate this setup into the case?
GoodToGo
3,516
Thanks for the reply kamel. Will take a look at it.
I have one more question. I am shipping this internationally, so I don't want to miss anything. If I use this setup as above, is there anything I might need? I want to eliminate any additional shipping at all. Please do let me know. I don't know if I can get any additional things from out here.
aigomorla
21,087
3,595
which vendor are you going though? and where are you located?
GoodToGo
3,516
Originally posted by: tylerdustin2008
You all mean teflon tape? I think so.
Not sure what you mean... :confused:
Anyhoo, few more things on my mind:
1) Any more barbs required to interface with the pump, cpu block or anythign else?
2) Any additional things required to mount this into a mountain mod UFO?
aigomorla
21,087
3,595
you may need some screws. There on petras web site.
But everything else looks good. I hope you can get some zipties over there. You'll need some sort of clamps.
GoodToGo
3,516
Can you please elaborate what screws?
Also if I add a GPU block, do I need to add another pump?
Thanks again!
