Noob Overclocker need help
Wurmer
48
Hi All,
It's my first time at trying an overclock so I need serious help. My CPU is a 6850 and MB is GA-P35C-DSR3. I'd like to know what are the settings that should be changed in the BIOS as well as the one that should be left alone. What parameters are to be adjusted ? For now the only 2 parameters that have been changed are the RAM voltage so it can meet the manufacturer's requirements as well as the fan speed controller which is set to manual. I know I am asking a lot and it can be bothersome for experienced OCer to answer such questions but well....We all got to start somewhere. In any case, if there is a guide of sort for that MB I would gladly read it
Thanks in advance
jawknee530
213
set your memory multiplier to 2x so it runs at an effective 800 and set your FSB to 400 and you'll have your cpu at 3.6GHz. you may need to set the cpu voltage higher or add .1v to your chipset but I think that it will work if you keep the voltages at auto. I wouldn't put my voltage over 1.45v personally. once you have your oc stable lower the voltage in steps and test it for stability with prime 95 while monitoring your temps with core temp. get the lowest stable voltage so your cpu will run cooler.
InfoTiger
1,186
I got a problem with my E6600 and GA-P35-DS3R(F5 Bios): CPU-Z only shows 6x multi.
I even cleared the C-MOS. I tried turned on and off overclock.
In bios it shows 9x multi. I could turn up and down FBS.
Just wondering which component is defected CPU or Motherboard?
Wurmer
48
ok I have tried some setting here to OC my rig, I took exemple of this dude which has a similar setup, he used a Q6600 instead of my 6850 and the MB is a bit different.
Here are my settings
Robust Graphics Booster - Auto
CPU Clock Ratio - 9x
CPU Host Clock Control - enabled
CPU Host Frequency - 400
PCI Express Frequency - 100
CIA2 - Disabled
Performance Enhance - Standard
System Memory Multiplier(SPD) - 2.00
Memory Frequency - 800
High Speed DRAM DLL Settings - Option1
DRAM Timing Selectable - Manual
4
4
4
12
ACT to ACT Delay TRRD - Auto
Rank write to read delay - Auto
Write to precharge delay - Auto
Refresh to act delay - 0
Read to precharge delay - Auto
TRD - Auto
TRD Phase Adjust - Auto
Sys voltage control - Manual
DDR2 over voltage control - +0.3v
PCI-E over voltage control - normal
FSB over voltage control - Normal
(G)MCH over voltage control - Normal
CPU Voltage Control - 1.2875V
When I leave the Bios and reboot, it's goes fine and I can see that duing booting it reads 9 x 400 3.6 Mhz but when using CPU-Z it says I am running at 6 x 400. What's happening here. Is it because I am using Vista and CPU-Z is not fully compatible. I am running the F2 version of the Bios, the one that came with the MB. I haven't flash it to the earilest version.
MetaDFF
145
I think what you are seeing is Intel's SpeedStep kicking to lower the multiplier (hence clock speed) when the chip is idle to save power. Trying disabling SpeedStep in your BIOS and checking your multiplier again in CPU-Z.
Wurmer
48
OK, I just took a fast peek in my BIOS but haven't seen the option of flicking On/Off the Speedstep. Under what tab should I be looking to find that setting ? InfoTiger, if you find it tell where please.
InfoTiger
1,186
I found some settings at advanced BIOS features:
CPU Enhanced halt(CIE0
CPU Thermal Monitor2
CPU EIST FUnction
