- Nov 16, 2004
- 59
- 0
- 0
Hello, I currently have a amd 3000+ and the game medival 2 keeps on pausing spiratically.
I am looking to upgrade now but dont know what to choose.
My budget is around $100 but I can buy used CPU if the seller seems trust-worthy.
I need your help to decide. I am confused as newegg has some 3800 that are 2.2 and some that are 3600 that are 2.4 (maybe not those exact numbers). The difference is however some are venice, san diego, etc.
I did also see a 2.6ghz fx-55 for 129. I dont know if that is a good deal or not.
-- On a side note, what is better to have - a dual core but lower ghz, or single core with higher?
Thank you for any helpful comments.
BTW, I am not an overclocker.
