As far as cooling goes I've got 2 80mm fans near the top of the case (Aspire X-Dreamer) blowing out and a PCI slot exhuast fan right under the graphics card, and I've got a Tr2TT CPU cooler (Thermaltake designed).
I know all the fans are blowing out, but I experimented with fan direction and this is the coolest - one, the other or both fans blowing in resulted in temps 1-2 degrees higher.
I bought some Arctic Silver 5 to try and cool the CPU down a bit, but when I tried to remove the heatsink, it seemed "glued" in place.
So here are my questions:
1. Are those temps too high?
2. What can I do to cool the case that I'm not doing? Will 120mm fans make a big difference?
3. What if I want to upgrade my CPU? What might the builder have used to bond the heatsink in place? Do I just need to give it a good yank?
Thanks in advance. Any advice would be appreciated.
