- Jun 13, 2003
- 123
- 0
- 0
I just recently built a new case, and had a couple of problems overclocking. First, it was combining my CPU and RAM overclocks, then it was my video card not reaching optimal speeds.
Intel E6600 @ 3.4 (I could reach 3.6 with decent temps)
Thermalright Ultra 120 Extreme
OCZ-8500 Reaper
EVGA 680i
EVGA 8800GTX
OCZ GameXStream 700W
CM Stacker 830
As you can see, I have a decent setup, with an exceptional case. However, my temps (according to NVIDIA Monitor) are horrendous. Last time I checked, my GPU was hitting 85C full load, and my case temps were 40C. I have two 120s as intake (one in the front, and one in the side panel), and three exhaust: back, PSU, blowhole. To top it off, the intakes both have less CFM than my exhaust, ensuring that I should have negative pressure.
Why would I be getting such bad temps? I manually set the GPU fan to 80%, and that brought the card down to acceptable levels. My case temperature should be much lower, however, considering how many reports of how cool this case was I received.
OCZ-8500 Reaper
EVGA 680i
EVGA 8800GTX
CM Stacker 830
