- Sep 12, 2001
- 48,518
- 223
- 106
Latest pic:
Maybe I'll get lucky...we'll see when I try it out.
Update:
Well, someone fried something. Is this something I can fix? I'm thinking I'll need a fine point for my soldering iron..
Somewhat visible damage
Now you can see it <-- does all that brown melty stuff mean something is fried on the other end, or is it normal on circuit boards? This is my first time messing with one..
amp5.jpg <-- trying to get a better pic now.
Pic
Pic2
A friend of mine gave me a two channel Alpine amp (2x90w) that apparently doesn't work - I thought I'd try it again before I throw it away, since I really could use it now. I plugged it in and wired it to my subwoofer -- the amp gets power, but I get nothing from the speaker. I tried again on one channel (rather than bridged)..still nothing. It's getting ~14+v on power, and it's showing 5.xx volts on the + and - speaker terminals. If I set + to positive and ground on the -, my multimeter shows 0.
Is the amp shot, or is there something I could check/maybe fix? The fuse is good and my wiring is good (connected my other amp, and the speaker worked fine). The only iffy bit is the ground..I just rested the ground cable on the terminal, rather than screwing it in (large cable..tiny space for it), but the amp is getting/showing power.
Any ideas, or should I throw it away?
Update:
Pic
Pic2
