- Aug 25, 2001
- 56,582
- 10,221
- 126
Trying to figure out why it seems to max out at 89C, even with both fans spinning at 2200 RPM, and WattMan Power Limit set to -20%.
Yeah, case cooling's not the best, with a 120mm intake fan, and a non-mesh front panel that draws air up from underneath the bezel.
But still?
I currently have it set now to Power Limit of like -30%, and Fan Speed set to Manual, Max of 2910RPM. HWMonitor shows 76C, fan speed 2900RPM,
Do have faulty heatpipes or something? Why is this card so hard to cool? Especially with dual fans?
Should I contact XFX about this? Nothing is overclocked.
CPU is Ryzen 5 1600, stock speeds, on water. (MasterLiquid Lite 120)
Also running WCG on 10 threads on CPU, along with F@H on GPU.
Edit: The problem is not temps, per se, but the fact that the machine will just reboot.
PSU is Antec Neo Eco 620C.
Edit: I installed 17.12.1 "Adrenaline" drivers.
But still?
