Nokia 5100/6100 Pack (li-ion battery, leather case, auto charging cord, belt clip) for $14.95 at Buy.com
Keroseen
Banned
The Nokia 5100/6100 Pack includes three terrific accessories no mobile phone user on the go should do without at a cost that won?t slow you down. The pack comes with the Sunpak® 900mAh (3.6v) lithium ion high capacity cellular battery so you never run out of power and miss an important call. When you are in the car, you can charge the battery with the mobile charging cord. Just connect it to your cigarette lighter and you can recharge your phone easily. Also included is the leather carrying case with a belt clip that allows you to stylish store your phone. These products, if bought separately, would cost over $70 at retail pricing. Order and save!
Mobile charging cord
Leather carrying case
Belt Clip
Very good deal, I purchased a vibrating LiOn battery for $18 from Onvia.com for my Nokia 6190 and I love it. How does this battery compare with the original Nokia battery? Same size? Same talktime?
Check this out: link and look under "eshop", Nokia "discount special, 7 package combo".
I bought this 7 piece set for my Nokia 5160. It was $23 + $6 shipping from him on eBay. Looks like it is $27 direct, but he may negotiate.
You get:
1) NiMH (900 mAh) Slim Vibrating Battery BMS-2V
2) Rapid Cigarette Lighter Charger LCH-9
3) Compact Desktop Charging Stand DCH-9
4) Belt Clip BCH-12U
5) Headset Kit HDC-9P
6) Leather Case
7) Flashing Antenna
It is all import stuff, I'm sure. But everything works great! The vibra-battery is excellent and is the same size as the original...charge time is comparable...maybe doesn't last quite as long. The handsfree earphone is wonderful. And even the leather case has held up very nicely. Under $30 is a good deal. Fast shipping, too.
LintBalll - Wow that is a good deal considering everything you get. I wish the Nokia 61xx's were as easy to mod as the Mod 51xx's are but I like the bigger size and menu's better on my 6190. Otherwise I'd own a clear see through 5190 with flashing antenna.
