I've got a dual 1800+ MP system in an antec server chassis (the one with the door). The CPUs are cooled with two Vantec CCK-6035s, and i have four case fans, and a dual fan PSU (Antec 400SL - 92mm on the bottom, 80mm out).
Its too noisy.
First of all the CCK-6035s come with these rediculous fans on them - they whine with a high annoying pitch. Took those out, replaced them with 60->80mm fan adaptors, and put panaflo L1As on them.
Im a little uncomfy with the temperature readout, as I used to be at 35 and 40, and now Im at 50 and 60C. Dont know if this is tolerable, given the (presumed) inaccuracy in the motherboard temp readings. For this reason Im scared about reducing the # of fans to get noise down further. From an empirical perspective, its obvious that fan noise is still the #1 culprit (silencing the HDs and such is not a factor imo right now).
Questions:
1) how can I get an accurate temp reading?
2) Can I afford to further increase case temp by reducing the # of fans (currently 4 + PSU fans)? If I replace them with all L1As will that be bad? Currently they're noname 80 mm fans
3) Should I put the L1As on case duty, and put a more scalable fan on the CPUs?
4) When a fan is "thermistor controlled" what exactly does that mean? Does that mean the motherboard controlls its speed when its plugged into the 3-pin plugs for CPU fans?
My case has two case fans in back, two in front, and the PSU fan. the front is intake, back is exhaust. can I switch this up to improve temps to CPUs? (how do I reverse the PSU?)
5) I've also noticed that the two exhaust fans behind the CPUS are not blowing out hot air, while the PSU is. Sure, heat rises and stuff, but there is an obvious temp difference between the two airstreams. Does this suggest that I can reduce the # of fans?
6) Finally, can I duct from the rear case fans onto the CPUs directly to eliminate the two CPU fans and simultaneously get better cooling? Can these work in "suck" mode, given my current temp settings?
Its too noisy.
Questions:
