Noise With flash and Headset
life24
283
Hello,
I use a headset and flash USB and input these front of case.
When i work with flash(read and write ) , i hear very noise in headset.
When end of work with flash , noise ends.
Why we have noise?
Thanks
eton975
283
8
Is the headphone jack properly grounded? Seems electrical noise is working its way through the internal USB and audio cables.
Coup27
2,140
Electrical noise / interference. Depends on the quality of the case, motherboard etc.
Try the 3.5mm port at the back of the motherboard. If it's a pain to get to, run a short 3.5mm male to female extension cable to the front of the case and use that. That one is likely to be more isolated.
Cerb
17,484
33
86
In a PC, this is almost never the case, especially for front ports. 0V is generally carried from the motherboard out to the front panel, along with the signals.
Coup27
2,140
I just tried it with my rig (sig) and I didn't get any noise. Probably boils down to the components. At the end of the day you get what you pay for.
Cerb
17,484
33
86
Not that they're all noisy; that they're usually not grounded (there's not much reason to ground it, and it could create a loop carrying unwanted DC currents if done, if the audio common off a bit from the case). I suspect the noise is either from sharing the 0V traces on the board with USB 0V, or having those traces really close, allowing for induced noise.
leeshin
Banned
Dec 24, 2015
this is the same problem i had whenever i attempt to see interesting flims in my PC and the annoying sound spoil the mood of mine. some of the discussion over there is helping me to get some idea on why it causes? but still the solution i dint get
Childs
11,313
7
Try using the back USB ports for the flash drive, or the usb port furthest away from the headphone jack. USB 3 devices can cause interference.
