canadianpsycho
Morning,
Both PSUs are about 20 bucks Cdn. difference at the moment.
Here's what I'm wondering.... Is the ability to control the 3, 5, and 12 V rails a bigger plus then the huge amperage (relatively speaking) of the Noise Taker and its 2 12V rails?
I'm not really concerned about overall power (doing fine with a 400W atm, so I'm sure wither will be fine) but what I'm looking for is most stable for my P4 rig with Raptors, DVD-RW, 9800 Pro, MAX 3 mobo, etc.
The Antec and Enermax both have same Amperage on the 3.3 and 5 V rails. However on the 12V the Antec has 24A (adjustable), and the Enermax has 31A (16A on 12V1 and 15A on 12V2) but not adjustable...
Any opinions? Is it a wash, and just go with the cheaper PSU?
Thanks.
Thanks.
