- Jul 13, 2011
- 1,501
- 23
- 81
Every now and then, my tower that is in a Coolermaster HAF 912 rattles. There are two distinct noises that occur often, and I'll try to describe them...
- One is a high-pitched metallic rattle that cycles in slow waves. A gentle tap on one of the two fans in the system (front panel and back panel) stops it.
- Sometimes that high pitched rattle becomes a more rumbly sound. Not like a HDD grinding or defragging but rather like a low-pitched metallic rattle. Again, a gentle tap of the case stops it.
But annoyingly, one usually turns into the other. It's infuriating because it will begin all on its own and then it just keeps mounting like water torture and you just want to let out a frustrated CRT TV smack to it but I know that's not conducive to helping.
If you ever had a CRT that would begin to lose its signal every now and then, you know what I'm talking about. It's the same stupid logic as smacking the remote when it won't respond.
I've tried looking for this when the HDDs are spinning and when they're not and it doesn't seem affected by either of them. Does anyone know of anything I can do as it seems that a little bit of something vibrating starts up and just seems to ripple throughout the case getting louder and louder. Is there something I can buy or install in the case to dampen this?? It's driving me completely bonkers.
