Noise Ninja
pontifex
43,804
46
Is this the software that people rave about for fixing noise/pixelation in their photos? or is it another kind of Ninja?
i downloaded a trial version but I can't see where it makes any difference. I might not be using it correctly either, so who knows?
anyone use this that could give me a quick rundown on what i need to do?
Aharami
21,205
165
i get great results with neat image. i dunno about noise ninja. is it better?
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
I prefer Noiseware over Noise Ninja...
montanafan
3,551
I've heard a lot of people say they prefer Noise Ninja, but I use Neat Image and like it. I shoot a lot of sports in low light at ISO 1600 with a digital Rebel and they would be unusable without noise reduction software.
What ISO are you using and what are your settings in Noise Ninja?
pontifex
43,804
46
well, the pic was at ISO 400, but it looked really bad, it was really grainy. as for noise ninja's settings, i don't know. i clicked the button to analyze the photo or whatever then ran the remove noise function.
i found a little tutorial thing in the help of noise ninja and got it to work. it did make an improvement, but too much, imo. it looked like someone just used the blur function in PS all over the pic. it looked unnatural and really photoshopped.
Aharami
21,205
165
post the pic here. Lets see what we can do with other noise removal software
pontifex
43,804
46
at work now, so you will have to wait until i get home
randomlinh
linh.wordpress.com
I don't think you can go too wrong w/ any of them. I use neat image... program was a little confusing to work with, but worked well. I switched over to a mac so I'm left w/ having to use the photoshop plugin... I wish aperture would allow for it's own filter plugin system... it'd simplify workflow oh so nicely.
yhelothar
18,409
39
photoshop's own noise reduction seems pretty good to me.
It was comparable to noise ninja imo.
But either way, I prefer the sharp, detailed, and noisy look over the smoothed over, plastic, noise reduction look.
GTaudiophile
29,767
33
Where is the function located? You mean the slider withing the RAW dialogue? Seems to do nothing for me.
Which noise reduction programs are free of charge? :p
pontifex
43,804
46
Originally posted by: GTaudiophile
So which are you all recommending and how much does it cost?
each piece of software has different versions and different costs.
as to which one to recommend, i dunno. right now (to me) its either Noiseware or Neat Image.
Aharami
21,205
165
neat image 4.0 pro+
http://pics.bbzzdd.com/users/aharami/niece_nimgpro.jpg
did you use default settings or did you adjust? yours seems a bit sharper than the one i did with noiseware.
no. i didnt use default settings. modified it a little bit to leave some sharpness in and turned on neat image's sharpening a bit. neat image is cool because it has different settings where you can sort of bring an little-out-of-focus pic into focus
http://pics.bbzzdd.com/users/aharami/nimgpro_sshot.JPG
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
Just reduce Chroma noise. Leave the luminance noise. You'll keep the detail and get rid of the ugliness of the color noise.
To the OP: The god's honest truth is that I think the original image is the best. All the noise-reduced images have smearing in the hair.
ZV
yhelothar
18,409
39
ZV
Chroma noise often makes the colors look unnatural.
I still like to use noise reduction sometimes though. I just go back and history brush over the detailed areas.
gsellis
6,061
raises hand for Neat Image... I have even used it to clean up DOF 'noise' with good results (really, just making it smoother).
And I like it because the have a video version too. I have a VirtualDub plugin manager for my editor, so I can use it directly in my NLE (Neat Video).
