Well.. I guess you could get a Y connector, so you can plug the 2 fans onto the one header. Better be careful though, because 1) you're only gonna get RPM sensing on one of the fans, and 2) Don't pull more than a couple of watts (1-2) off the one header to the MB, otherwise you're likely to melt the header and that's not good..
