Noise Canceling Headphone, with airplane adapter plug
Status
Not open for further replies.
funboy6942
15,309
393
Linkage
Adapter for in-flight entertainment system connection
Use your own headphones to listen to in-flight entertainment. The adaptor simply converts the standard double-mono jacks to a stereo headphone jack.
3.5 - 6.35mm adaptor connects to all types of audio devices
With this adaptor, you can use your headphone on equipment with either 3.5 or 6.35 mm jacks, giving you a wider choice of audio devices.
Battery included so you can use your product straight away
No need to buy batteries to get started. Just drop the batteries in and go!
Features
Carrying pouch included
Electronics integrated
Foldable headband
Active Noise reduction
Excellent sound quality
Neodymium magnet
Comfort ear cushions
Full size design
Status
