Hi all,
Long time lurker, first time poster.
I've recently built a mATX build inside a Node 804. My part list is below;
Gigabyte GA-Z170MX-Gaming 5 Motherboard
Seasonic G-750 80Plus Gold 750W
Corsair Air Series SP120 Purple LED Fan Twin Pack (going for a purple theme)
Corsair Hydro Series H100i GTX 240mm Liquid CPU Cooler
Western Digital WD Green 2TB WD20EZRX
Samsung 850 EVO Series M.2 500GB SSD
Intel Core i5 6600K
XFX Radeon R9 Fury X 4GB
Fractal Design Node 804 Mini Case Kingston HyperX Fury HX426C15FBK2/16 16GB (2x8GB) DDR4 Black
Basically I'm looking for the most optimal setup of fans for cooling performance and where would be best to place the Fury X Radiator (currently have it at the front of the PSU chamber).
My current setup is this;
In the chamber with my GPU/CPU/HDD/SSD two front intake fans, cpu radiator acting as exhaust (dual fans)) and one rear exhaust.
In the PSU chamber I have the fury x radiator exhausting out the front (best solution I could come up with as it doesn't fit the rear 120mm exhaust spot in the GPU chamber), one in take from the top and one exhaust from the rear. The other two mounting positions in that chamber are basically useless due to the size of the Fury'x AIO radiator.
This is my first PC build. Current temps under load are system 40ish degrees Celsius, CPU 35 degrees Celsius and GPU around 65-70 degrees Celsius. I'm kind of concerned the GPU is so hot due to the lack of cool air for the radiator in the second chamber.
Anyway, could I improve this setup?
Thank you in advance!
Intel Core i5 6600K
