Noctua NH D14 Touches GPU
MongGrel
38,466
3,067
121
China_FR4_G10_Epoxy_glass_cloth_laminated_sheet_Electrical_Insulating_material20123132023089.JPG
I'd still stick a piece of this under it maybe.
Go to a local tool shop and be nice and just ask, they might even have a spare piece of scrap laying around they'd give you for free, ya never know.
Tht or something like those washers, they look like they are probably Delrin.
mvbighead
3,793
this can cause the slot to warp...
so id go with the index cards unless u had a really thin plastic spacer.
Those are a bit thicker than would be ideal to use, I'll give you that.
My issue is with covering something like that completely with an index card or wrap or whatever. All in all, that space still can dissipate some heat. If you put an index card there, you're basically providing some layer of insulation. It may not be much, but will it be too much to the point that the card becomes a few degrees warmer?
I've bought nylon washers at lowes/home depot/menards that would provide adequate separation and yet still leave the space open. Use a spot of hot glue to hold them in place on the heatsink, and it should all be fine.
mfenn
22,400
www.mfenn.com
