m3ta1head
Installed my new D14 yesterday, needless to say it was a bit of a squeeze. I was having problems getting it to sit straight-the darn thing kept wanting to rotate slightly to the left. I remounted both the hsf and bracket several times in an attempt to get it straight. This is as good as I could get it:
The bottom of the D14 was actually touching the solder joints on the back of the STX and shorting it out! For now, I've resorted to spacing them apart with a credit card, but a more permanent solution is needed. I can move the STX to the slot immediately below my 7950, but that will block airflow to the card significantly. I can put it in the second pci-e x16 slot, but that will throttle both slots back to x8. I've also tried moving the 7950 to the bottom x16 slot, but the heatsink on the card does not clear the power/reset headers for the case. Whoever laid this board out should be shot!
Anyone have any suggestions on how to rearrange/fix things, short of going out and buying a new mobo?
