I was tempted to try out IX and just never went there myself I guess.
Looks as though we have a few parallel conversations here; DrMrLordX is currently on a different track at the moment, but he raised attention to Indigo Xtreme.
So -- JediYoda! Been a while, Bro'!
JEDIYoda said:
DrMrLordX said:
Actually, IX is the best.
Define best. . .
At the simplest level of evaluation, only "performance" rules. Indigo Xtreme trumps CLU by a couple C degrees, which trumps IC Diamond by a degree or two in turn.
On that fundamental criterion, it's all about thermal resistance and its inverse -- thermal conductivity. No more -- no less.
But throw in the other factors: ease of application; re-use-ability; various risks; etc. Then you have a "qualified best" or multiple criteria in the score.
With the Indigo, you have to cure it, and some of the installation advice suggests using a hair-dryer to raise the processor temperature to 80C which will melt the IX "metal pad." Once done, you have the other factor: ease of removal. As I understand, it forms an amalgam with the copper surfaces, so removing the HSF from the IHS is no picnic, either.
Folks may please argue and contest these points, but if I were ever tempted to use IX, these factors -- whether assumed, exaggerated, misunderstood or simply correct -- led me to defer it and abjure it.
Then there was CLU or its predecessor from the same outfit -- Cool-Laboratory. "Little balls of liquid metal rolling around on your motherboard like spilling Mercury on the floor in a sort of pinball frenzy." CLU is apparently less likely to result in any such mishap than what came before it.
So I stuck with IC Diamond -- a thermal resistance which is "way down there" and just a tad higher than the gallium-indium-whatever formulations. It's not conductive. It won't roll around and get lost; it won't wrench your processor from the socket when you want to remove your HSF or waterblock for cleaning; and it can be literally re-used.
It's just a slight bitch to apply, and a tad more expensive. Of course, the criteria change when you alter the cooling configuration: for instance, de-lidding the IHS and either chucking the IHS altogether for a bare-die approach, or reinstalling the IHS and replacing the TIM with one thing or the other. In that latter possibility, damage to the die may occur even from micronized diamond particles. Similarly, with Indigo Xtreme, I'm only guessing that "You're really stuck." Of course, the IX wouldn't form an amalgam with the processor die. But I never saw any attempts to use it in the de-lidded arrangement.
Like they say at the nudie-bar: "Pick your poison!"
